Главная arrow Новости arrow APS High Flow Pod Intake WRX/STi
11.12.2009 г.
Система впуска холодного воздуха APS для WRX/STi.
Опция диаметр трубы под маф: 65мм, или 70 мм (+ 20 у.е.)
* APSWRX-HFA/01 - 65mm internal bore diameter near the Air Flow Sensor in order to maintain stock Air Flow Sensor operation and to work in harmony with the stock engine management.
* APSWRX-HFA/02 - 70mm internal bore diameter around the Air Flow Sensor in order to support extreme levels of horsepower without overwhelming the stock Air Flow Sensor. Note that this option requires additional engine tuning.
390 у.е. [100% предоплата. Под заказ.]
